Drop in 1000cc injectors
JustenGT8
Anyone found a large flowing, decent drop in injector? I have already converted to a Bosch style plug, so just looking or something the right height and 1000cc/min plus flow.
Yeah IDs are the obvious choice but $$$ and i'll need to do the loom again rolleyes......I may actually need bigger again on E85 but should just be right with 1000's i think
ID did have a 1600cc but they have been discontinued.
Dont you have a first born child to sell? or a Mrs to work on the street corner? Failing that maybe porn off a Kidney ( you have two anyway ) and if none of those work then maybe sell off your left testicle. You know the ID's will be worth it.
We have also used some bosch injectors by machining the fuel rail to suit the larger bosch o-ring. We use 1600cc in RX7's so maybe that would solve you issue.
