stilltippin
There are two places a MAF can go ..Between aircleaner and turbo [draw through] and anywhere after intercooler [blow through].. Usually atleast 8" straight pipe before so air is equal over maf...
The intake is more dense on blow through.. Depends how these air meters work ?? I have seen Supra meters used..
Tmk they are draw through ??
Thank you for the clarification, I'm a bit dense sometimes too. I think I will be able to achieve close to 12" of straight pipe before the MAF, but then right after the MAF it does a 90*. I have been basically copying another fellas design and he seemed to have success with the MAF setup like this, but he came in at more of an angle. Now that you mention the two styles, I notice it now. I'm looking through Super Street as I'm sitting in the airport and I am starting to see the difference. I definitely don't have space to put the MAF before as I'll most likely run a screen because a 4" filter probably won't fit.
I really do appreciate the help, in a perfect world I would be buying a standalone. In time that will come but for now, I just want to start the thing. I'd be interested if I could make the Supra MAF work, I'd assume it's a Karmon Vortex meter as well. Isn't the point of FI to have more dense air, so wouldn't it be better to put it as a blow through to achieve a denser intake charge?
