You can view the ECU pinout(plug configuration) on another page within this very site, thanks to Lextreme!
I was able to do this and then go outside and jump the circuit by baring the wire near the plug for testing purposes.
I later soldered and heat shrunk the connection back again after I figured it out.The connector had lost it's "spring-action" inside.
