XR8tt
Has anyone had issies with harmonic ballancer breaking the key on 1UZ crank???
They look very suspect on modified engine...
I will be machining a longer grove in crank snout with longer key...
I know some "modiified" 2J GTE's stripping keyway...
It from memory the key retains timing gear and ballancer...
The ballancer is the least of problems, but the timing gear is a worry!!!!
