Miles,
A good friend does lots of old Ferrari restorations and repairs.
One of the perenial problems he sees is workshops milling heads and dropping the deck height to a point where valves and pistons get a bit chummy.
Another problem is corrosion due to running water only in lieu of coolant. The peope can afford the finance repayments but not proper servicing!
He has a guy who welds the entire surface of the head then mills it to stock tolerances.
I have spoken to him about doing this to our engines to increase the chamber area. He doesn't see any problem other than the usual cam timing bit you would get with thicker headgaskets.
The process isn't expensive but if you are pulling the heads I would look at new lower comp pistons (not necessarily forged) as the "correct" way to lower compression. It will cost a bit more but then you cam timing is correct.
