What do you guys think of this setup?
Oh there's an improvement LoL! 2mpg. I can get that swapping from 5w-30 to 5w-20 on this v6.that could potentially reduce vehicle fuel consumption by up to 10%.
Bullshit. Completely... To start with. That's the kind of crap only seen around peak torque at WIDE OPEN THROTTLE when the average exhaust is expelling the exhaust at roughly 240-260feet per second. Around 76m/s.Typically the 800º C gases have a velocity of 60m/s and a mass flow rate of 0.05 kg/s, providing enough energy to spin the generator at up to 80,000 rpm and create electrical power of up to 6kW—sufficient to handle the car’s electrical systems.
What is the advantage of compound turbos?
Would this system work on pump gas?i am a diesel mechanic myself and have installed one of these compound turbo setups on a 24valve cummins in a friend of mines truck.
the turbos are setup so one turbo (right of the manifold) can spool almost immediatly to spin the other turbo almost instantly after the first one. on his truck, there is litterally ZERO lag in both turbos. and it can boost near 30 psi on his stock internals right off idle. it is basically mimicking a variable geometry turbo by using 2 turbos.
it now pushes somewhere in the range of 700 to 800 horsepower/1100 to 1200 ft/lbs of torque and can burn up 44 inch tires in 4 wheel drive. its pretty f***** sweet.
Incorrect. When compound charging. One compressor feeds another compressor. You couldn't feed both a compressor, and turbine into the same place. Remember that the pressure restriction that esists infront of the turbine is normally 2-3 times the amount of compression seen on a turbo.I thought compound turbos used the compressed air of the first turbo to spool the seccond turbo (ie. connect the compressor outlet of the first one to the turbine inlet of the seccond one).
The best way to do it with multiple turbocharges. Is to feed each turbine with a set number of cylinders. Turbines do not like restrictions, and nothing is more restrictive in an exhaust than a turbine.If both of the first turbo's outlets (cold and hot side) fed into the turbine inlet of the seccond turbo, then it would produce some extra boost! Would be really cool with a split entry turbo like off a GT4 celica/MR2.
When you take two compressors in parralell to feed an engine. You are not adding pressure. You are simply adding the flow rates.What is the advantage of compound turbos?
Yes Lextreme. You can compound charge on anything you want. In fact. Take your twin turbo & re-route it to compound charge. But I would greatly advise you to knock your daily driving boost psi on your wastegates down to 33% of their values now! If you were to leave them where they are & just route one into another & cool the both. You'd probably get atleast another 30% power gain out of that thing.
Bring on the water injection!
