OK Boyz an Girls...Knowing that what I'm asking is Sideshows and Glovermans business:wall: ..here is what I've done and I'll to explain it so as to not give out too much and seeing as the info IS on the diags..
Ig Relay= on = powering B/O on IG Main relay..powering the ignitors,coils,injectors..as seen in the sc diagram.the way i see this is it's sole purpose:fingersx: .
Ig Relay = start = obviously start starter motor,also sending a sig to pin 77(STA)
![Eek! :o :o](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
k:
EFI Relay = on = here's where things get a bit lost..I think because that a curtain pin is NOT giving power(maybe a loose pin or is waiting for something else):hmmm: :wtf: What I have done is power this externally and I get the enine to run and power everything as it should BUT not from the ECU.
Fuel Relay = obvious powers fuel pump,hydrofan etc.
Everything runs fine when warm:newangel: ..BUT when cold it doesn wanna start and is like a pig:bsflag: ..(I think the pin the EFI relay is suppose to be powered by is not giving power on the ECU-hence I have powered it ext..)If I could get the power from the ECU as per diag..then I can re wire the relay and It should then give me power and also the critical thing..resetting the ISCV after turning off(Cold start)
I've spend probably over 30 hours in total going over and over the diag and it all points to the ECU powering the EFI relay(I'm not getting power here)Am I missing something,could it be a loose pin,ecu buggered..?basiclly the engine runs beautifull when warm and I have no complaints..cold is another storey-any ideas..I hope I've tryed to paint the picture of what I've done..any help would be great..Cheerz..:feedback:
