SprinterTRD
Kdog,
Yes they do predict the crank position, but as I stated earlier they can predict the crank position with an accuracy of 0.1 DEG, they also have plenty of time to process other complex tasks. Just have a look at the MoTeC M800 Specs.
Now other aftermarket manufacturers that use 8 bit or 16 bit microcontrollers may struggle only calculating crank angle with one tooth per TDC using a time based calculation, but these days most OEM ECU's are using angle & time based calculations to sort out true crank position for example Bosch 60-2, Nissan 360 optical, Toyota 12 tooth on crank.
I think you need to think a little harder.
