Since completing my 1UZ/ W58 conversion some three years ago I have been frustrated by recurring clutch issues (squeaking and a sort of grinding and a loss of pedal smoothness). Different hydraulic throw out units, bearings and clutch/pressure plates have only resolved the issues for a short time, only to return.
The following pictures show the face of the domed thrust bearing on the Howe throw out as well as the wear marks on the fingers of the pressure plate (clutch/pressure plate only 1500km old).
As I see it there can only be a couple of things that could be causing these noises to keep recurring, one being the bearing is not centred properly or two the Howe unit is vibrating or wobbling (not detected during inspection).
My thoughts are that if the bearing were centred and rotating with the pressure plate, wear marks should not be evident after such a short period but if there is an alignment issue, other tell tale problems would be evident such as worn spiggot bush.
Because I'm running out of ideas, I have just bought a CRS bellhousing to trial and to get away from the existing adaptor plate, but because of exhaust proximity, I will have to stay with the Howe unit and not use an external slave. I'm running out of ideas as to whats going wrong and my ability to enjoy my drives is being eroded.
Anyone prepared to offer any suggestions?????????
