Cheap headers vs sc400
they probably flow better do to having larger diameter runners, but they aren't even length.
they also need modified to fit in the truck still dont they?
A little off topic but how is your motor located around the steering stabilizer? I cut mine off along with the loop it mounted to, I have a front sump.
G'Day mate. :)
Standard practice to do that.
I did not want to have to lift the motor a mile in the sky so after reading about it I cut the lug that the damper bolts through on the drag link off then cleaned it up a little.
I am going to make a small bracket that clamps back in the same place but swing the damper in underneath.
Am starting to think about removing all of the independent suspension and go solid axle. S.A.S. :D
