getting really tired of these issues, but put a bit of time in to try to figure it out.
tried with each ignitor unplugged, no change with #1 unplugged but without #2 it would turn over but not fire at all.
traced the wires from both ignitors, all seem fine but IGT on ignitor 1 has a bit of resistance, and sometimes no continuity. Wriggling the wires doesn't seem to change it. so plugs are probably ok
started fine :-s got codes out and only got oxy sensors.
tried to start again, fires but wouldn't run. Code 14 is back. tried unplugging ignitors and swapping the plugs, seemed to be that the #1 plug is dodgy. checked wires again, all fine bar IGT1 still.
wired that to the ECU but it made no difference.
now the thing turns over but wont even fire. Its driving me crazy! it is inconsistent which makes it hard to diagnose. Are any of these fused somewhere I havent found? what else can i check?
