Hi guys,
I've read so much that my eyes are almost bleeding. Seems there are a buttload of ways to do it, but now i've over-researched and have gotten myself quite confused.
I have a '92 1UZ in an FC RX7. Its attached to an R154 box. Should be mounted this week, and then its time to figure out some kind of management.
The car WILL be turbo'd, but maybe I will get it running NA first.
I pulled the motor from a donor SC400. I have the motor, all sensors, and loom.
Now i'm looking for a simple, effective setup.
What sensors can I ditch from the motor?
I assume I am better to swap out the MAF for a MAP system (or at least upgrade the MAF)
Should I use my loom, or build one from scratch? I am swapping out the injectors so will at least need new injector clips. If I loose a couple of the sensors I might as well make myself a new loom I guess.
What megasquirt should I buy? I'm assuming the 3. What addons are needed?
Ford EDIS or Wasted Spark?
Please guys, any help is REALLY appreciated, as I have read myself into a hole here....
Thanks in advance!
Rich
Thanks in advance!
Rich
