Rodney baker
hi peeps
dam soarer has a host of electrical issues gauges keep blowing the fuse that supplies power to them . changed gauges for a known good pair, no better swapped fuse for a auto reset circuit breaker all was good for 3 months now over a week the cruise control stopped working even flashed up a red warning as it failed the gauges go straight out when you turn on the ignition ,as soon as ignition is on it starts cranking all by itself and it starts and the starter keeps running if i put it into gear the starter stops as soon as i put it in P or N it cranks again
i have replaced the ignition switch no improvement
