$upra$rule
I have a 91 LS400 motor in an 82 Supra, and am considering modifying the stock manifolds for forward facing turbo use. But I want them to run forward and up (to keep the AC & Alt.) instead of forward and down. This means the bolt pattern to the head is the reverse of what I need. Looking at the original manifold, only the #1 & #4 flanges are welded to the manifold, the #2-3 flange is slid over the manifold pipes and then they appear to be flared out.
I'm looking for suggestions (or somebody who has done this) for how best to remove, reverse top-to-bottom, and reinstall this flange. Is there a way to unflare and reflare these pipes, or would it be better just to cut off the flare and have to weld them to the flange after flipping it? I don't want to shorten the distance from the head to the bend in the manifold as I need this clearance for the AC. I'm not a welder, so will be paying somebody to do this.
Thoughts? Suggestions?
