Hello all just starting my uz swap into a 95 toyota pickup v6 3vz. I have had this truck for 8 years and slowly put moreo and more work into it suspension, Cage and now finally getting to the motor. The hoursepower can not keep up with the suspension and tires anymore. I have been doing research for a while but probably dont know everything i need to know to make this swap flawless but if i dont start i wont ever get it done. So here it goes.
Still not 100% wheather i am going to run a manual trans, would like to but trying to work out the details. I have an R150F with transfer case but am only running 2wd as this is a desert racing truck. I am a little worried about endurance and strength of the trans and adapters(flywheel clutch etc) if any of you have an opinion on the cheapest easiest way and reliability to mate the r150f to the 1uz advice would be great.
here are some picks of work started yesterday
