So, I stripped the wiring down to a standalone engine management harness more than a year ago. Ran it for awhile, then replaced ECU caps and a few other things. And ran it several more times as I modified the transmission, and tested the exhaust coating. Ran great every time.
I was tinkering on it yesterday, and I'm getting really close to starting it up in the truck. Since I had the oil pan/pump off since the last time I ran it, I wanted to prime the oil system. I'd already installed the 4Runner sensor for the gauge, but I had an old Subaru switch nearby, so I installed that and wired it to a test light. Used a jump pack to boost the voltage and spin it over faster, and it didn't take long to build pressure.
2020-07-29_09-10-27 by
Numbchux, on Flickr
Next up was to pressurize the fuel system. I jumped power to the pump and it came on and built pressure, and immediately found the flare nut on the fitting that I'd left loose to install the lines....whoops. Tightened that down and tried again, good to go. Screw in the damper rose up, no leaks.
I desperately need to get this thing out of the garage for awhile, so I decided I'm going to run it on the temporary wiring (inline fuse holders, loose relays, rocker switch to simulate an ignition switch, etc. Only thing wired to the truck beyond the battery is the fuel pump). Had to reconnect the ground wires to the relays, then I flipped the switch and both relays powered up (EFI relay is wired correctly, ECU controlling it, passes Kelvin's test for the most common mistake), CEL comes on.
I cycled the "key" a few times, and the relays all work as they should.
Then I hooked up the wire between the fuel pump controller and the pump, turned the "key" on, and no pump. I have power to the controller, pump works when jumped 12v, but it doesn't want to prime. I disconnected the battery for a few minutes, in case it wasn't priming anymore since I had cycled the "key" a few times without the pump connected.
So, something has likely come disconnected or damaged during install. I'm not sure how much diagnostic the ECU does before priming the pump, in my experience (usually with Subarus...), if they have good powers and grounds, they'll prime the pump. I had the harness on the front of the motor apart since the last time it ran, but that looked decent, and no connectors broke. Obviously problems could be hiding, and I'm assuming I'll have to remake that harness at some point, but it doesn't seem to fit my symptom.
Next time I get a few minutes, I'll bring the laptop and multimeter (it was in my wife's car yesterday), and do some more testing, and check for DTCs. Might try to turn it over...
