A miracle motor infact.... I would maybe guess 230whp with side exhaust, deletion of MAF, map and tuned...and running just an alternator...Maybe 230rwhp and that would be pushing it.... On an early model 4.0 liter 1uz-fe I would think you would definetely need cams and maybe some head work to achieve that kind of horsepower rating along with all the other goodies...260rwhp would be amazingly sick on that stock motor as is!!! Man, I got to hit the NOS to get up to those numbers on my 1uz-fe and the only difference between the two motors in question is that I have the MAF intake which flows decent, and a high flowing rear exhaust section which flows great with straight thru rear mufflers.. Side exhaust and a MAP intake I don't think would make an additional 45rwhp?...Again, 215rwhp is what i got after a good tune job...However, I do run all the crap off the crank, AC, power steering pump, etc.. Even with the AC pump deletion, and powersteering deletion you may pick up what 5whp or so?....Hmmm...
I am suprised I am the only one that is questioning or inquiring how it is possible to obtain those dyno numbers...Cribby and Jbrady should surely know this...
Also with your MAF deletion you would be pulling in hot engine heat intake air with the filter pod positioned directly above the motor...Right? Not so sure that would completely outperform a BFI MAF intake setup that is drawing in only cold outside air...The MAF intake section is small for intake air to pass but is surely adequate for only N/A use.... Still just very curious...
