Something new is coming along! Before the main picture, I have some teaser info and pictures.
I'm running 8 RX7 fuel injectors with 460cc/min and a AEM standalone ECU made for 93-98 Supra TT. However, with a handful of knowledge and magic of Mitch Pederson, he made it work on my 95 SC400 single turbo. He also helped to sort out the bugs from the ignition timing and fuel issue. I couldn't thank him enough.
Picture 1: ARP head studs and Cometic head gaskets are used. I had to re-torque 2 times. It's holding up so far.
Picture 2: Engine after the dyno.
Picture 3: Dyno result from 13 lbs of boost. I'm glad with the power curve. It made 334 rwhp and 371 rwtq.
I'd expect more rwhp & rwtq with 13 psi, but somehow the dyno machine showed a lower number from what I expected. The dyno machine is a single roller Dynojet with a somewhat old computer so I don't know if it read correctly. I'll take my car to another Dynojet machine to see if it's any different. If it's the same, then it's time for a bigger turbo. The turbo already was maxed out. It's a T04 turbine with 60-1 compressor housing.
However, I'm very happy with the result. The car ran very strong and smooth.
