stevechumo
Does anyone know of the engine oil pressure at the oil pump and at the oil filter housing?
Thx.
			Thx.
Thank you. No wonder my turbo blows the seal. I'm putting on the oil restrictor now.70-80psi when hot depending on oil type and temp.
100psi when cold.
That oil pressure is enough to kill 3 turbos at the same time.I was seeing 85 psi at high rpm warm, but now hitting 110 psi warm at 7000rpm.
That oil pressure is enough to kill 3 turbos at the same time.![]()
I didn't install the oil pressure gauge, so I don't know. From the researches, many turbo guys say the turbo leaks the oil the most when the engine idles or when it's cold. So that can relate to the created high pressure when the engine idles or is cold. There's no perfect solution for lowering the oil pressure to the turbo. It can make the turbo hotter with less oil traveling through it. A turbo timer is neccessary in this case.What's your psi at idle on cold start and after warm up?
Ryan
If there's oil seal issues with high pressure oil supply..I didn't install the oil pressure gauge, so I don't know. From the researches, many turbo guys say the turbo leaks the oil the most when the engine idles or when it's cold. So that can relate to the created high pressure when the engine idles or is cold. There's no perfect solution for lowering the oil pressure to the turbo. It can make the turbo hotter with less oil traveling through it. A turbo timer is necessary in this case.
Red Supra,
Very interesting that you measured the oil pressure at different engine conditions.
Depends on oil pressure ?? Also SOME turbo's have built in restrictors..I'm afraid 1mm is too small, so I use 2mm hole. Do you think that's good? I never had to use oil restrictor on 4 banger Hondas.![]()
