Ok, I have had a lot of feedback regarding the universal flange and the intakes. I have incorporated
a lot of the updates + request to this edition, that I hope is the last.
People have asked for:
- An intake flange that turn the port "up" so the top end is horizontal.
This is no problem to draw, the problem comes when you try to get somebody to machine it. This is
the same situation regarding the ports on the ITB intakes, not all CNC shops have the equipment to
machine a transition from a round to a "squashed" shape, so I keep it as simple as possible and this
means the ports on all the ITB intakes must be hand finished.
- Instead of saying no to the above, I have added a flange to the top end of the universal intake.
This will make it possible to bolt either straight or angled ( 32 degrees ) pipes to the universal flange
so the top of the intake can be flat.
If you are looking for the original/stealth look it should be possible to use a stock intake top, of course
with a little bit of work....
- Port size. It's up to 30 x 51 mm now, this is the same as a 41.2 mm round pipe.
This should be enough for most people, if bigger ports is needed there is enough material in the
flanges/intakes to port 'em.
- I have added more "meat" to the flange against the head.
Two reasons, better sealing and to have enough material there for increasing the port size.
All the drawings have been updated with the improvements where they apply and the Jaguar
supercharger intake have been redrawn. I got back my setup from a friend and put in on the engine
and started measuring and found that I had misjudged how much space there is so a complete
redesign was needed. It still have intake ports similar to a 40 mm pipe, but there is a transition
from 24 x 58 mm towards the supercharger to 29 x 51 at the head.
Here is a picture of the last version of the universal flange.
