Hey guys, I'm building a 27 track T roadster. My plan is to use a 1UZFE v8 and completely discard of the engines computer and controls. Then build an intake manifold and install a carburator.
I have seen guys take late model 4 and 6 cylinder engines and doing this so I don't think i'm being totally ridiculous. My only concern is the 1UZFE ignition. I have seen that the 1UZFE has 2 distributor looking things on the intake cam shaft. Are these distributors in the traditional sense and is the control unit seperate from the ECU? If not could a guy rig up a control unit and coil from like MSD? I'm guessing you would have to use two control boxes and coils, one for each distributor, would I be right? That's if there is no way to use the stock stuff.
I'm sure the 1UZFE has a knock sensor of some sort to adjust the ignition timing, does anybody know if this ties in with the ECU or ignition control unit if there is a seperate one?
Is there anything I'm not thinking of to get the engine running? As you can tell I'm pretty clueless as of now, so tell me if I'm being totally retarded or it can't be done for some reason.
Thanks for the help.
