Patrick1uz
currently it is 40% off here
Its from a store called Princess auto, not sure if you have it down there in the states?
Heres a link
https://www.princessauto.com/en/detail/valve-spring-compressor/A-p8003725e
Currently it is on sale, works so easy on the head, I was scared it wouldnt but so simple
If you cant order it let me know, we can work something so I can ship it down to you.
As the covers are white I would expect dirty hands to leave crap on them.
Melvin lives in Bangkok Thailand.
Thanks. I have one of those "pliers". Bought it on Amazon.
I found that getting springs/retainers/keepers off and out was not tricky.
The cumbersome part was to assemble the pieces after having changed the oil seal.
Used the valve plier in the pic but the tricky bit was to get the keepers in place.
The first cylinder head took hours and hours to complete, with 3 keepers lost.
The 2nd head took about 4 hours and a half, no keepers lost.
(thats a bit more than 15 minutes for assembling one valve - maybe not too bad?)
Looking forward to this build
Good luck !
Mine it works super easy, I will take some pics later tonight of it in use, found it pretty easy,
Where did you order oil seals from?
15 mins isn't to bad, I take my time as well, better to make sure it all gets together properly.
Oil seals; from a car dealer, Yeomans, (heavy on Toyota) in Brighton, UK.
(the spare part manager there has sorted me out several times with spare parts that Toyota Thailand is not able to deliver)
Well if you say 15 minutes/valve ain't too bad maybe I shouldn't complain, but my expectation would be kind of 2 minutes/valve.
I got pretty frustrated with clamping on the plier then playing with knitting pins and mini screw drivers to get the keepers in place, and stay in place when the plier was released.
Putting keepers in place in the retainer before compressing the spring never worked, the fell off during compression.
Tried oil/vaseline/grease in order to get the keepers to stick, did not work, didn't try glue though.
Just one idea re colours.
Keep the colours relatively light, that makes it easier to spot potential leakages of oil and/or water.
