PROJECT V8LGA (Volga+V8)
I thought I could add my own car here after quite a number of posts and threads started here.
It has a long story involving a number of engine conversions, new suspension, all 4 disc brakes (instead of 4 drums), new rear axle with Detroit TrueTrac diff, and a number of smaller goodies.
Currently, it has 1uz-fe vvti in it. The engine came off some '2000 UCF21 Celsior with about 60.000 km on it. Timing belt and water pump were like new upon replacement. Nothing has been done to increase engine's performance, however it's enough for me 99.9% of the time
Short specs
Wheels - 15" , 195mm wide for winter, 215 for summer
Rear diff: 4.1
Fuel pump: Pierburg, 160LPH @ 3.5bar. Stock 3.3 bar regulator off LS430 with a custom off-tank adapter
Exhaust: 3UZ headers, 2x63mm into single 63mm, lots of space restrictions here
ECU: factory unit 89661-50521 with immo bypass, sub-o2 sensor emulators
Plan to use European ECU 89661-50440 to get rid of the speed limit, but it won't control Celsior's hydro fan speed.
Weight: 1570 kg with fuel and me onboard.
Cx: 0.41 (factory spec)
The body is 1970 model. My car was built in 1990.
I use the car daily. For summer season, its fuel consumption is 15.5 L/100km (city) and 11.2 L/100km (highway). That's 15.18 MPG and 21.0 MPG respectively.
Short specs
Rear diff: 4.1
