Hi all im dan from sydney. im new to lextreme.
Ive got a 1uz hilux that ive had for 2years now. its been all good up until now.
Problems:
-on start up it runs VERY rich. black smoke comes out the exhaust, leaves sooty/black residue on the ground. petrol smell in the air.
-while its warming up, engine is very rough, idles very low too. Give it some throttle and it sounds like its sucking loads of air thru the intake and stalls.
-once its warm it runs ok, however it seems to be fuel cutting while driving under load. usually at the same rpm (i dont have a tacho connected but it feels like 4000-5000 rpm. When it happens the trucks rear wheels pretty much lock up from the compression. (is this a fuel cut????)
-it also stalls when slowing down coming to a stop.
What ive done:
-fitted 2x brand new coils
-checked and cleaned Idle Control Valve
-cleaned the Crank Angle Sensor
-checked for vacuum leaks
-checked ecu for corrosion
-checked ignition leads
ALSO:
id like to know how to get diagnostic codes from my engine. i dont have the plug that is normally inside the cabin in a soarer. Can i flash out codes using a 12v test lamp from the diagnostic plug on the engine.
Thanks in advance for any help. much appreciated![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Problems:
What ive done:
ALSO:
