S SuperRunner New Member Aug 6, 2006 #1 Here are my progress pics soo far. comparing the transmissions. The stock RV tranny is PUNY!!! Engine fits in great with slightly modded exhaust manifolds Looks good from here. mid sump oil pan, or is this rear?
adxx Member Aug 6, 2006 #2 SuperRunner said: mid sump oil pan, or is this rear? Click to expand... This one is rear
S SuperRunner New Member Aug 9, 2006 #5 radiator clearance ( I need to remove that hydro fan pump pully) Modified RV trans mount Mounted transmission
S SuperRunner New Member Aug 9, 2006 #6 oil pan clearance. If I remove the studs and just use regular bolts, I should be ok...I hope! Engine mount Drivers side firewall clearance
S SuperRunner New Member Aug 9, 2006 #7 Passenger side firewall clearance. If it was for the A/C, the engine could go back another 2 inches. And here is just a picture of the engine going in. Doesn't look like it will fit...but I tell you, it does.
S SuperRunner New Member Aug 10, 2006 #8 Had to shave the oil pan to clear the steering. Also need to lengthen the pickup tube in order to clear the shaved part. Here is what it looks like on the engine A side shot
S SuperRunner New Member Aug 13, 2006 #9 Put motor in for the last time today. I had to keep testing fitting the exhaust and finally just welde on a 2 bolt flange were the 3 bolt flange was. I also used an old tensioner with an aluminum mount and cut if off and welded it to the hydro fan pump in order to re-gain some clearance. And the oil filter bracket fits just fine. Doesn't even come close to hitting the frame.
S SuperRunner New Member Aug 14, 2006 #10 Here is a picture comparing the radiator clearance before and after the hydro pump removal and modification. And then from underneath at a look at the exhaust flange. The exhaust needs to come down between the frame rail and the torsion bar. Very tight fit.
S SuperRunner New Member Sep 22, 2006 #11 havn't had time to work on it much lately, but I have almost got the radiator done, and let me tell you clearance is tight. here is a little video clip of the engine running with just the downpipes. http://www.supracharged.com/swaps/87rv/rad/open_pipes.wmv http://www.supracharged.com/swaps/87rv/open_pipes.wmv I also have the exhaust system done. That is about it so far.
S SuperRunner New Member Oct 18, 2006 #12 Got the swap pretty much completed, here are some pics. http://www.monster-performance.com/sale/winnebago.html
