A quick update on our progress.
The wiring is in, and I'm pretty happy with how it all turned out. We spent way more time than expected running all of the wires, it was better to take it slow and make sure that they were all completely hidden than rush and make a f%$k up somewhere along the way. The only wiring that you'll see will be the battery cable where it goes to the isolator - almost made a stuff up there with the connection too, the iso switch needed a set of auxiliary contacts on it for the ignition so that the engine doesn't run on with the battery disconnected (alternator powering everything.... easy mistake to make)
Also got the radiator mounted, it needs the outlet pipe relocated still, but that's on the cards in the next week or so. Chris managed to fit a 16" fan on the back side of it too, so it should pull through some nice cold air.
We'll take the diff out next week so that that the mounts can be changed over to the hilux one, and then I reckon we're on the home straight.
Can't wait for this to be finished now.... the novelty is wearing off.
Muzz
