So the idea was to take a classic RX7 (if such a thing exists) and make a weekend track and show car, by adding a decent engine, brakes, and strengthening up the chassis with a full rollcage. Purists will be up in arms about bastardising a rotary powered weapon, but they’ll just have to get over it won’t they.
Engine wise, the 1UZ was a logical choice, I’d built up a couple previously and there were plenty of options for performance upgrades later on. The plan was to run the Seven on the standard ecu for about 6 months while we ironed out the bugs etc, and while we put together a twin turbo 1UZ with after market ecu, big injectors etc.
Width and lengthwise the RX7 engine bay would easily accommodate the bulk of a 1UZ, but the height posed a problem. The height from the sump to the plenum was about 650mm and in the 7 the critical height from the underside of the bonnet to the crossmember and steering linkage was 530mm. It was pretty obvious that it wasn’t going to fit, so we removed the 1UZ sump and set the engine down on the crossmember to see exactly how much clearance we had (spaced up about 20mm so the crank wasn’t fouling). In the pics below you can see that one of my fat fingers just manages to squeeze between the plenum and bonnet reinforcing.
