Hi all, think it's my first post here,
I'm currently running a 1uz from a celisor in my s13 drift car, I have it manualised with a 3sgte flywheel and clutch set up, the car idles great but the revs have always been limited at 4500rpm and recently the car won't run properly at all, yesterday in particular it would drive for 500 meters and then stop again. At first I taught it was the fuel pressure regulator or the afm so I replaced both of them, I set the fuel pressure at 45 psi and it idled perfect, I also replaced the plugs with ngk twin tipped plugs but nothing has worked, yesterday it was also back firing out the air intake with makes me think it's a valve or a cam problem as i swapped the ignitors at the track yesterday. Has anyone had problems like this before? Really need some help as I'm lost with it, thanks.
