ash New Member Nov 22, 2011 #21 new oil pump gears machining out oil pump housing this weekend if i get time... more volume.
ash New Member Nov 22, 2011 #22 XR8tt said: .. Tight-sh mains clearance & good oil !!!... Click to expand... no thanks you can use that for you engine....
XR8tt Active Member Nov 22, 2011 #23 ash said: no thanks you can use that for you engine.... Click to expand... They where supposed to be question marks ???.. On bearing clearance... Yes better to have oil volume over pressure...
F FoPar New Member Nov 22, 2011 #24 we went 1-thou over on the mains, had no oil pressure. went back to factory was all good. however we didn't have a trick oil pump just the factory.
XR8tt Active Member Nov 23, 2011 #25 They pump a shitload just on the starter... In my engine the crank is lanished...
B BlackUZZ31 Member Feb 13, 2012 #27 how much of an increase in area? might have to do something to hold the front oil seal in like the 2jz guys do!
