1UZ Swap:
Got my harness back and needed to redo the sub harness that connects to the Cam and Crank Sensors in the front of the motor. It was brittle and waiting to snap. After the rewiring that part, my motor would not start. It cranks only. I recheck my connection with 3 different wiring diagrams and everything is correct.
I test a few things and this is what I found:
I have no IGT1 & IGT2 voltage. Cam and Crank Sensors are in specs. Did a continuity check back to the ECU and there are no shorts found on those wires. Also continuity check the wires back to both ignitors. Both ignitors were also grounded. No issues found there.. IGF1 & IGF2 has 5.0V when ignition on. Fuel pump is turning on when cranking. Driver side coil resistance is a little high by 2 points. Didnt think that could be a problem since both head are not sparking up and no signal from ECU to trigger it.
What could I be doing wrong? Is there something I'm NOT checking?
