i made my own sump out of steel, its very easy to do, i made a template of the bottom out of 8mm plate then fabricated the rest out of 1mm sheet and tig welded it up
Dunno what it is.
Didnt really have time over the weekend to sort it out.
Will try again next RnR, but we did thrash the **** out of her for about 150kms.
95% of the time she is only running at 50% power, but occasionally she pulls full power.
she went from 70 up to 110 in about 8ish seconds up a hill, in 4th.
Cant wait for full power
So no luck at the tuner. Sorry to hear that. Did you ever figure out why it was firing to often? Your running the Delco unit, right? Is the ignition module getting "confused" and firing as if were a pair of V8's?
I saw on your wiring diagram all the injector wires come together at d15/16. Are they suppose to be batch fired by the delco or are they suppose to be like factory http://www.lextreme.com/lexuecc2.pdf
Don't know if that is why you were running rich or not. Not very familiar with the Delco.
Nah, we gave up.
Didnt have the time to perform any R&D anymore.
You have 3 option tho.
Use the one "Max Power" is designing
Buy D!cks Superbox (best option)
Use a Lada Niva ignition module (apparently these use 1 input, and can control 2 coils)
