Whilst the 1UZ swap is fiddly I would do it again if the opportunity arose.
Oh and I love my Rover and wouldn't swap it for any other 4x4.
I'm looking to do the swap myself, but on a 1991 Land rover discovery 1.
It is currently fitted with a 200tdi motor and an LT-77 gearbox, but it has the terminal rust problem and as such, i'm throwing away most of the body and making my own tube frame, since the chassis is in remarkably good condition.
I'm hoping this will help me a bit with the "size" problem as I can build the front around what is required.
From what I understand I will need a rear sump from a Soarer 1uzfe to clear the steering.
I will post pics of my progress (this is my first engine swap)
Hallo Guys
Just my 2 cents...
I did the Lexus transplant in my Disco about a year back. I will not go back to the old Buick engine ever. I used the Lexus gearbox, had it mated it to the LR transfer case. I did a few offroad tracks with it and I am very satisfied. I had a mishap wit the standard ECU (Igniter had a bad earth) so I am running with the Spitronics ECU. The only drawback when off roading is using the engine for braking on steep downhils. (Automatic).
I have attached some pictures of the engine and the gearbox adapter.
The shaft was hardened. (tempered)
Have fun....
Paul
Nice swap ....
How is the deferential holding the power ? any issue?
are you using the lexus radiator ? any other modification/ fabrication to fit ?
I'm planning to buy another disco for sand fun with 1UZ on it!!!!
currently having a 2004 disco (4.6L) 19" .... DD.
hi all this is my first time on the inter web.
I have swapped out my rover 4.0 V8 and used a 1uzfe into a type 2 disco 2000 a lot of work.if anyone is interested i have lots of pics
