Back to the original question of this thread about head gasket sealing:
I found this interview at Corvette Action Center about developing the 638hp supercharged LS9 engine. Interesting detail about how with computer simulation you can actually "watch" what is going on and see the head and gasket move and flex "virtually". Also of note is the 5 microns flex per layer of MLS gasket technology.
CAC is Corvette Action Center
SW is Sam Winegarden
http://www.corvetteactioncenter.com/specs/c6/2009/zr1/sam_winegarden2.html
CAC: So the third challenge was?
SW: We took a couple of iterations to get the head gasket sealing right. With the combustion pressure we run on this thing to hit that 620+ number, we had to do a couple spins on the head gasket design and that's one reason why you see the 12 mm bolts.
CAC: A few motors gave up the ghost on the dyno, huh.
SW: Actually, no, however, we burned up an awful lot of computer time.
CAC: I guess I should have said, "the virtual dyno".
SW: Yes. A lot of computer time.
CAC: When you do these simulations, do they have, like...a graphic of the engine running?
SW: (laughs) You won't actually see coolant spew out from the head gasket. What you do see, though, is the model run though the thermal test. You can actually watch the cylinder head lift-see it, as it moves and you can watch what's going on as you go through the cycles. When you see that, you go, "Now, I understand why I need an extra layer in the head gasket."
SW: There are five microns of lift per layer of gasket. We ended up with enough lift at these combustion pressures that we had to go to the bigger bolts and put an extra layer in that MLS head gasket in order to keep the thing together.
Now, that analysis, because it is so complex, takes several days on the computer because the finite element is so detailed and the model so complex.
