So, I recently just lost my lisence from getting too many tickets so I've decided that for the next 6 months, while my SC is sitting, I'm going to do a slight rebuild on the engine and if I can afford it, give my 1uz a little bit of boost
I've pretty much come to the conclusion that the centrifugal supercharger is the cheapest and easiest way to go but what I'm unsure of is what a completely stock 1uz is capable of handling.
Like I said, I'm on a bit of a budget for now. I am going to eventually do a stand alone, bigger injectors, fuel pump and maybe even lextreme rods and pistons but is it possible to run like 6psi safely on the stock ecu and without upgrading the fuel system? Basically, what is the minimal set-up for running boost?
Thanks
Thanks
