1uz-fe no injection pulse
Deodat
Hi guys im strugling to get injector pulse i checked
1.timing ✅
2. Fuel dampers✅
3. Wiring ✅
4. Fuel pump✅
5. Spark ✅
6. Earth✅
What els can be the problem because the injectors are getting power just no pulse
Injector pulse is created when the ECU switches the injector circuits to ground. It uses the same input signals as the ignition circuit (cam & crank sensors) to determine engine position, and then calculates which injector drivers (transistors) to switch on/off.
If you have ignition spark but no injector pulse, it would likely be either be a power supply or ECU issue.
Did you measure for 12v at each injector or at the fuse?
How are you checking for pulse?
