Arctic Wolf
Hello! I've pasted the following from the owners club uk, where I was advised to also take a look around this place as well ![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
First off a brief summary of myself and then what I plan to do.
I own a 2002 Mitsubishi L200, it's a project truck and has several modifications as is, with others on the go. The major failing of the L200 is the pansy 2.5TD engine in a two tonne truck! So in case you haven't guessed yet, it's coming out and a 1UZ-FE is going in, along with the gearbox from an LS400.
The Aisin auto gearbox in an LS400 is the same box that Mitsi use in the L200. So the plan is to take the box and engine, fit them into my truck and use my transfer case to retain 4 wheel drive. This would be the first time this has been done to an L200 in the UK I believe, but I understand it has been done in New Zealand. It has also been done in the UK to several Pajeros - again the same gear box - and so far it has been done to nine Toyota Hilux surf's that I know of - once again, same gear box.
I won't be doing this conversion myself. I carry out most of my own work but I am too busy with actual work and I only have a driveway which isn't great for these big mods. Between myself and the chap who will be doing the conversion (also the same chap who did the 9 Hilux conversions) we should have all the technical bases covered.
I thought you guys might be interested to know about this. As I am to be an owner of a 1UZ-FE engine I thought I best get to know it a bit better! I have done about as much research as I can before joining here. I understand it is a well built strong engine.
Also maybe you would be able to assist with pointers for a donor vehicle. Obviously cosmetics don't matter, nor write off's or non road worthy vehicles. Just has to have a good engine and box. All the conversions I have been able to trace have been done with donor vehicles that have covered 100 - 150k miles. All report that the engines are 'just about run in' which is what I like to hear. My previous vehicle was a 4 litre Jeep, the engine in which is bullet proof so I am looking for a similar long term reliability and natural strength from the conversion.
Any thoughts or pointers or comments please just fire away....
