Gday,
I have a 1988 toyota 4runner that has had a 1uzfe conversion done with the standard G52 manual transmission. It starts well both hot and cold, drives great, revs freely, idles fine, normal power. The problem I am having is once the engine is warmed up when you are driving at any speed if you depress the clutch the engine will cut out. When cold this problem does not kill the engine (possibly due to cold idle I'm guessing). Once warm, the engine will cut out when coming to a stop with the clutch depressed every time. If you leave it in gear and let the wheels keep the engine turning you can engine brake all the way into first gear and if you slowly depress the clutch when doing ~2-5km/hr it will just hold on and recover to a steady idle. After the car cuts out once you turn the car back on it idles smoothly at the correct rpm.
I bought the car with this problem and the previous owner (who is the owner after the owner who did the conversion) said the previous owner before him said he needed a pulse reduction sensor to fix this problem. He said the wiring is there ready to be hooked up. I'm not sure this is the problem but if it's a clue to someone who has done a conversion that might spark an idea then that would be good.
My thoughts are speed sensor, however through reading I'm led to believe no speed sensor is needed to keep it running fine. This is the joys of buying a conversion already done.
Any further information needed just ask, thanks in advance.
Cheers,
Peter.
Cheers,
Peter.
