melvinmelvin
ran the engine for a couple of hours today,
for sure, the temp sensor is in the hot stream rather than the cold stream
so swapped the hoses on the oil filter flange where the oil cooler is connected
didnt get around to check the results though,
new problem popped up, suddenly the radiator and oil cooler fans didn't start,
anti freeze overheated and blew out of the radiator
so, will need to check all the electric and the relays related to radiaror fans and oil cooler fans
all sorts of piss surface when don't use a boat and an engine regularly
well, keeps me busy at least
