Heres something I found, but my work computer won't let me see the site that refers to it sorry
that is a pretty engine, but odd as it may sound there is no room to do that in the gen1
there lacks about 3-4 inches forward and up to do any kind of standard install, and no amount of cutting will earn you that, there simply is not enough car.
the drivers turbo had to go forward and down so that the downpipe could turn to miss the steering, otherwise it would have needed an S in it, and there is no room for that, the pass turbo had to be turned so that the downpipe went straight out between the head and the strut tower because it cannt go down like the drivers side due to alternator, and its just...*&^&)))(& tight all over lol
if a person wanted to mod the brake booster and run a bulge/scoop/cowl hood, you could get away with the stock oil pan, but the engine would sit higher, and cause other problems for turbo plumbing, not so much for NA
there is no way in hell you can have AC on the car...not a chance, sucks too, because i live in the hell hole of the USA, right now its middle january and was 83F today...
also had to run internal gate turbos, because there isnt enough room for external gates and the plumbing, i mean really, it "could" be done...but it would be an absolute nightmare and its bad enough as is
and yes, no wiring on the engine yet
