Hi All,
Bolted up the head today using the 1/2 arp studs (ford cleveland) and the factory type mls gasket.I enlarged the gasket hole with a stepped type bit.
Eric's comment about crap getting between the layers is true ,but the lexus gasket is not crimped around the cylinder and only in two spots.I cleaned in between the layers with degreaser , air and soapy water the heat dried to stop any rust.If you wanted to be extra sure it is easy to put the gasket apart, clean and reassemble.This will not work of couse with a gasket that is crimp around the cylinder.Also 1 stud has to be shortened to clear th cam gear. Hope this helps anyone thinking of doing the same. Darren.
