stevechumo
I'm currently building a turbo system for my SC400. I'm thinking about changing out to thicker steel head gaskets (with 100% stock internals) to be safe for around 12 psi of boost.
I don't know if it's possible for this engine with stock head gaskets to withstand this 12 psi. If it's possible, then I'd stay with the stock head gaskets to save the hassles. I might pull out some timing and save the stock head gaskets. I've run 9 psi safely on stock Honda engines, which are relatively weaker than this 1UZFE. Has anyone tried more than 7 or 9 psi on this 1UZ with stock internals? Did anyone have to pull out the timing at all?
Any info. is greatly appreciated.
