cyberdiamond
Brand new CNC Billet Alloy Oil Filter Adaptor to use for a remote oil filter and / or cooler setup.
Also great for conversions where space is limited.
This will suit the Toyota / Lexus 1UZFE 2UZFE both early and late (VVTi and non VVTi) and 3UZFE
The adaptor has circular grooves machined around the ports to hold the two o' rings (standard size, found anywhere for ease of maintenance) that seal against the engine / block.
Also has a 1/8 NPT port which can have a / or multiple T piece(s) installed to run an oil pressure sender, temp sender, ports for gauges, oil feed for turbo's etc or any combination.
Included in the sale is the Billet Alloy Block and the 2 needed O'Rings (factory sender shown in second picture is for illustration purpose only).
