Hello Guys,
( GS NEWB )
I need your help on some diagnosis by video.
This guy was told his car needs a new engine. A little background on this car, @ 189K it Had a Timing Belt kit done..water pump etc etc. 2 days later, ( I watched a video of this happening ) The car was hissing white smoke just behind the upper rad hose housing, And ran rough. The radiator cap disintegrated leaving the spring and some metal ring inside the rad which I later fished out. I assume some rubber is still in there. I also noticed the reservoir had a leak/gash in it, so I temp. patched it with plastic weld.
* No CEL codes but I observed the oil light on
* Found in Glovebox Toyota paperwork and it read previous DTC prior to repair P01349 & P0441
* I'll be buying a compression tester, and also do a leak down test
Here's a vid if you guys can help.........
Thanks,
Joel
_ Click Vid to watch_
Part 1
Part 2
**OFFICIALLY MY PROBLEM NOW!** I bought it!
( GS NEWB )
Thanks,
Joel
Part 1
Part 2
