ivan129
BlownZX
- Messages
- 302
- Location
- Some where down under
1UZFE Non VVT. I plan to swap my rocker covers, putting the Left on the Right side and vice versa. The reason for this is because the intake plumbing is being moved from the right side to the left. If I swap the rocker covers, the oil drain holes in the metal baffles inside (under) the rocker covers will no longer line up with the drain holes in the head and block and will mean that oil will drain over the side / top of a bucket. Will this cause oil usage? My other option would be to remove the baffles from both rocker covers. Advice / opinions welcome. Thanks.
