1UZFE Sump Flange AutoCAD drawing files
Ian231
USA
Does anyone have the drawings available for download?
Right, as I have had a few requests for this file, I'll just upload it here
to make it easier for everybody.
The drawing is in AutoCAD 2000 format.
  • 1UZFE sump flange.zip
Does anyone have a front sump, 1UZ steel sump pan flange drawing?
I used the original sump to make a custom one for my Surf. Have found that it weeps slightly and the clearance isn't the best.
So want to start from scratch. Have searched but can only find the upper sump drawing.
Cheers.
Thats the aluminum section, or upper pan. I need the lower pan, or steel section. Thats the one I haven't been able to find.
Cheers for the reply. Anyone able to move this thread?
it was £25, i had mine done in bradford but there will be loads of laser cutters closer to you than that, one thing i noticed is that one of the bolt holes is slightly out, i just drilled it 2mm bigger and the bolt went in ok.i messed a few up but what i had left over are on ebay.
Not a problem, the least I can do, plus I'm planning to fab my own sump as the UZ's is huge compared to the previous engine I was going to use. Would love to go dry.
Anyway I like to give something back!
