ivan129
BlownZX
- 302
- Some where down under
Hi Russ, Run a ground behind your button, set a pullup in the config and adjust the table to detect the gnd where want it to engage or disengage 4th. Understanding the wolf logic can be a challenge at times.
For the VSS (variable reluctor), one side goes to ground, the other to the wolf input pin.
Here's some snips from a V550 for the VSS. Change the pin and set up the divider when your on the dyno.
