When I was making my Twin Turbo LS400. I did it the old school style. My source of oil was from the oil filter housing where the oil pressure sensor is located. I removed the oil pressure sensor (OPS) and thread it with 1/8″ npt and using a T to get the oil from there. This method is ok and functional but its just not worth the hassle. I decided there must be a better method. I visited my locally fitting shop and ask them to do some research and order me some special fittings. They found these but I order for them to make any money. They would have to order at least 10 pieces. I used couple and gave some to friends. I only have few left.
This kit comes with two fittings. You will get a T fitting with one male and two female along with the 4-AN outlet for your turbo or supercharger oil supply. This kit is completely bolt on and no threading required. This kit will work on All Lexus and Toyota V8 Engines. This kit would work best with thread seal. $25 per kit.
