We are proud to introduce the new Megan Racing high performance aluminum radiator. Anytime an individual introduces their car to a racing/drifting environment, the temperature of the vehicles engine will skyrocket. One common and effective method of reducing engine temperature is to employ an aluminum radiator.
This is a cost effective upgrade which can ultimately save an engine during competition or spirited driving. Often times, a temperature drop of twenty degrees or more will be noticed when using an aluminum radiator. Also included is a 1.1 BAR radiator cap. Cap itself is like $40 already. Some other radiator doesn’t come with cap but this one does.
This radiator is amazing. If you really keep good care of it, it should outlast your car. Keep it the fluid clean by changing it once a year.
Here is the same radiator in my Twin Turbo SC470:
ATTN: Please FLUSH the radiator before installation and properly take all the air pockets out. If its not properly installed, might cause the motor to over heat due to low coolant or air pockets in the cooling system. Just for $265 plus shipping. It is literally cheaper then radiator from Lexus dealer. NOTE: Some Mods are required!
Will this radiator work with a 1991 LS400? Is it streetable with a stock thermostat temp?
Do you have a radiator for a 1995 Supra twin turbo automatic transmission?
