NOTE: If the vehicle is equipped with Air-Ride system, installing the suspension might turn the Stability control on. THIS WILL NOT AFFECT YOUR RIDE QUALITY.
The Street LP Series is our new Luxury Package, using similar specs & set up design as Street Series, (not too aggressive) offering spring rates for a more comfortable ride, but still giving you the sporty feel & control.
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
NOTE: The VSC Light may illuminate due to installation of the damper system. At this time Lexus/Toyota does not want to disclose how to remove the light from appearing. Similar instances happen due to a change in tire/wheel combination.
Features:
– RWD only
– Spring Rates: 12kg Front and 8kg Rear
– 32 Levels of Adjustable Damper
– Pillow Ball Upper Mounts.
– Rubber Dust Covers.
– Adjustable Ride Height
– Aggressive Spring Rates
– Single-Cylinder Design
– Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
– All coilover damper kits come with 1 year manufacture-defect warranty.
– All Hardware is Included
Model | Year | Note: |
SC300/SC400 | 1992-2000 | Available |
LS460 | 2007+ | Available |
LS430 | 2001-2006 | Available |
LS400 | 1990-2000 | Available |
IS300 | 2001-2005 | Available |
GS300/400 | 1998 – 2005 | Available |
GS300/350/430/460 | 2006+ | Available |
Testimony by JamesN of CL and Lextreme member:
1995 SC400
I had the Megan Coilover on my car for 3+ years. It’s been performing great since the first day I got them. The various setting able me to setup my suspension just the way I like them. Not too harsh for everyday drive. Yet, still handles good around turns and cornering. They are bang for your buck when versus against the higher ends brand coilovers in my opinion.
1993 Lexus LS400
I’ve recently got these Megan Coilover for my LS400. I’ve heard of good reviews about them on forums and the price are very affordable. Once put them on my car it changes the ride quality dramatically. It handles better, sharper steering, and still maintain a comfortable ride. The various setting allow me to adjust my ride height perfectly. So far I think it worth every penny.
all them are the luxury performance series $900 Plus S40 shipping to Lower 48 states.
