UPDATE: A limited supply of the original best-selling Lextreme
1UZFE EGR Delete Kit remains. If you own a 1UZ from 1990-1997, you
really need to get this kit! Email me at
[email protected] for help with ordering or questions. This will probably be the last kits I have made.
Garrett claims the GT series turbos are much better then the old school T series. They claim the GT turbos will spool about 1,000 rpm lower then the previous generation. Here are the Specs of each turbo and compressor map. I also included the 1UZFE to 3UZFE Airflow.
Here are the Air Flow Chart for the UZFE:
Here is the spread sheet of 1UZ to 3UZ Air Flow Chart
Here is the Specs of GT Turbos:
Garrett GT Turbos
Compressor Specs |
CHRA |
Turbine Specs |
Max. Rated HP |
Part No. |
Wheel Dia. |
Wheel Trim |
A/R Ratio |
Bearing System |
Wheel Dia. |
Wheel Trim |
A/R Ratio |
130 |
GT-12 |
41mm |
50 |
.38 |
Standard |
35.5mm |
72 |
.43 |
220 |
GT-15 |
45mm |
60 |
.48 |
Standard |
41.2mm |
72 |
.35 |
260 |
GT-20 |
56mm |
55 |
.53 |
Standard |
47mm |
72 |
.46 |
280 |
GT-22 |
52mm |
60 |
.51 |
Standard |
50.3mm |
72 |
0.56, 0.67 |
280 |
GT-22 |
59.41mm |
52 |
.42 |
Standard |
50.3mm |
72 |
0.56, 0.67 |
320 |
GT-28R |
Call |
CALL |
.6 |
Ball Bearing |
50.3mm |
62 |
.64 |
500 |
GT-30R |
76.2 mm |
56 |
.6 |
Ball Bearing |
60mm |
84 |
CALL |
520 |
GT-32 |
71, 76mm |
52 |
.5 |
Standard |
64 mm |
73 |
.78 |
660 |
GT-35 |
71, 76mm |
52 |
.50, .60 |
Standard |
68mm |
84 |
1.18 |
680 |
GT-35R |
82mm |
56 |
.7 |
Ball Bearing |
68mm |
84 |
0.82, 1.06 |
700 |
GT-37 |
76mm, 82mm |
52 |
.54, .70 |
Standard |
72.5mm |
84 |
1.12 |
750 |
GT-40 |
82mm, 88mm |
50, 54 |
.58, .72 |
Standard |
77mm |
73, 84 |
0.94, 1.34 |
1100 |
GT-42 |
94mm, 102mm |
53, 56 |
.6 |
Standard |
82mm |
84 |
1.15 |
1100 |
GT42R |
94mm, 102mm |
53, 56 |
.6 |
Ball Bearing |
82mm |
84 |
1.15 |
2200 |
GT-60 |
141mm |
56 |
1.05 |
Standard |
130mm |
84 |
1.47 |
To match the perfect setup for your horse power
needs. Just match the above air flow chart with the
approperaite engines and the boost u want to run. The
airflow (Text in Red) and pressure ratio (Text in Blue).
The Pressure Ratio is on the right side of the chart and the
flow rate at the bottom of the map. For example 8 psi is
your goal for the 1UZFE (SC400, LS400 or Crown). Here is your
air flow and pressure ratio:
Pressure Ratio:39.08
Air Flow for 1UZ @ 8 psi:1.54
To learn more about “how
to read compressor maps“
Here are the compressor maps:
